ZDRAVÍM VŠECHNY !!! POTŘEBOVAL BYCH POMOC....NEJSEM ŽÁDNÝ VELKÝ MODELÁŘ ALE V POSLEDNÍ DOBĚ JSEM SE DO TOHO PUSTILL VÍCE A POTŘEBOVAL BYCH PORADIT Z NĚKOLIKA VĚCMA: ZAJÍMÁ MNE JAK LEPIT ZADNÍ KŘÍDLA U F1 A ZDA A CO SE POUŽÍVÁ NA PNNEUMATIKY PO NANEŠENÍ DECALU...TUDÍŽ ČÍM SE NATÍRAJI NEBO ZDA SE NECHÁVAJI POUZE Z POLEPEM A TÍM TO KONČÍ...DOCELA BY MNE POMOHLO I JAKÉ POUŽÍVAT LEPDLO...ZATÍM DĚLÁM Z TAMIYOU EXTRA THIN CEMENT A HUMBROL PRECISIONPOLY CEMENT KTERÝ MI DOST VYHOVUJE...TAMIYA MÁ LEPIDLO TAK SPÍŠ NA DVĚ VĚCI NĚCO DRŽÍ...NĚCO NÉ...CO VÍCE DODAT...KAŽDÁ RADA JE PRO MNE VYVÁŽENÁ ZLATEM !!!!A PŘEDEM VŠEM KDO NAPÍŠOU MOC DÍKY !!!Venca
